<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-information-regarding-automatic-transmission-shift-lock-control-function-200.html</guid>
										<title>2007 Corvette: Service Bulletin: Information Regarding Automatic Transmission Shift Lock Control Function</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-information-regarding-automatic-transmission-shift-lock-control-function-200.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin: Information on Driveline Clunk Noise When Shifting Between PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-information-on-driveline-clunk-noise-when-shifting-between-park-and-drive-park-and-reverse-or-drive-and-reverse-214.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</guid>
										<title>2006 - 2009 Corvette Z06 and ZR1: GM TechLink: Excess Oil in Air Intake Snorkel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2009-corvette-z06-and-zr1-gm-techlink-excess-oil-in-air-intake-snorkel-109.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-campaign-removable-roof-panel-95.html</guid>
										<title>2005 - 2007 Corvette: Campaign: Removable Roof Panel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-campaign-removable-roof-panel-95.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</guid>
										<title>2006 Corvette Z06: GM TechLink: Vehicle Identification Number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-z06-gm-techlink-vehicle-identification-number-319.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</guid>
										<title>2006 Corvette: Service Bulletin:  Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-diagnosis-of-cracked-or-broken-transmission-case-271.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</guid>
										<title>2006 - 2008 Corvette: GM TechLink: 6L80 or 6L90 Automatic Transmission Shift Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2008-corvette-gm-techlink-6l80-or-6l90-automatic-transmission-shift-conditions-72.html</link>
