<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-rocker-arm-cover-gaskets-185.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</guid>
										<title>1990 - 1996 Corvette: Oil Life Monitor: Reset the Engine Oil Life Monitor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-coolant-usage-recommendation-service-information-533.html</guid>
										<title>1988 - 1991 Corvette: Service Bulletin: Coolant Usage Recommendation Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1991-corvette-service-bulletin-coolant-usage-recommendation-service-information-533.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-axle-lube-change-935.html</guid>
										<title>1984 Corvette:  Service News:  Axle Lube Change</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</guid>
										<title>1992 - 1996 Corvette:  Service Bulletin:  Oil Leaks Between Intake Manifold and Engine Block</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</guid>
										<title>1985 Corvette: Recall: Mass Air Flow Sensor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</guid>
										<title>1991 - 1992 Corvette: Service Bulletin: Fuel Pump Driveability Issue - Diagnostic Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-1992-corvette-service-bulletin-fuel-pump-driveability-issue-diagnostic-information-528.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</guid>
										<title>1984 Corvette:  Recall Notice:  Product Safety Campaign 84C01 A.I.R Pump Pulley May Loosen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-notice-product-safety-campaign-84c01-a-i-r-pump-pulley-may-loosen-1129.html</link>
