<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-minimum-idle-speed-revision-184.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Noisy/Fraying Accessory Drive Belt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-noisy-fraying-accessory-drive-belt-527.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</guid>
										<title>1985 Corvette: Recall: Mass Air Flow Sensor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-recall-mass-air-flow-sensor-replacement-541.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-service-engine-soon-light-code-36-pfi-engines-vin-codes-f-and-8-540.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Service Engine Soon Light - Code 36 PFI Engines (VIN Codes F and 8)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-service-engine-soon-light-code-36-pfi-engines-vin-codes-f-and-8-540.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</guid>
										<title>1986 - 1990 Corvette: Service Bulletin: New Design Cylinder Heads Production Change Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1990-corvette-service-bulletin-new-design-cylinder-heads-production-change-information-539.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l98-engine-throttle-body-diagram-542.html</guid>
										<title>1985 - 1991 Corvette: L98 Engine Throttle Body Diagram</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l98-engine-throttle-body-diagram-542.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</guid>
										<title>1992 - 1996 Corvette:  Service Bulletin:  Oil Leaks Between Intake Manifold and Engine Block</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-oil-leaks-between-intake-manifold-and-engine-block-62.html</link>
