<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-window-regulators-replacement-181.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-windshield-wiper-adjustment-667.html</guid>
										<title>1984 - 1996 Corvette: Windshield Wiper Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-windshield-wiper-adjustment-667.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-side-door-lateral-movement-899.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Side Door Lateral Movement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-side-door-lateral-movement-899.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-chattering-wiper-blades-or-wipeability-646.html</guid>
										<title>1984 - 1996 Corvette: Service Bulletin: Chattering Wiper Blades or Wipeability</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-chattering-wiper-blades-or-wipeability-646.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-revised-body-paint-plate-information-location-663.html</guid>
										<title>1984 Corvette: Service News: Revised Body Paint Plate Information Location</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-revised-body-paint-plate-information-location-663.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</guid>
										<title>1991 Corvette: Service Bulletin: Squeak and Rattle Diagnosis Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Cracks/Damage to Cowl Surface</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-cracks-damage-to-cowl-surface-650.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-yellowing-paint-on-or-around-headlamp-doors-white-only-164.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin:  Yellowing Paint on or Around Headlamp Doors (White Only)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-yellowing-paint-on-or-around-headlamp-doors-white-only-164.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-technical-instructions-headlight-motor-gear-replacement-1222.html</guid>
										<title>1988 - 1996 Corvette:  Technical Instructions:  Headlight Motor Gear Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-technical-instructions-headlight-motor-gear-replacement-1222.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Roof Panel Attaching Point Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</link>
