<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-spark-plug-replacement-179.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</guid>
										<title>1955 - 1957 Corvette: Service Bulletin: V-8 Distributor Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1957-corvette-service-bulletin-v-8-distributor-chart-780.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</guid>
										<title>1958 Corvette: Service Bulletin: Nylon Headlamp Adjusting Screw Bracket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-nylon-headlamp-adjusting-screw-bracket-779.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-headlamp-flicker-778.html</guid>
										<title>1959 Corvette: Service Bulletin: Headlamp Flicker</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-headlamp-flicker-778.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1962-corvette-technical-article-diagnosing-fuel-gauge-malfunction-246.html</guid>
										<title>1953 - 1962 Corvette: Technical Article:  Diagnosing Fuel Gauge Malfunction</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1962-corvette-technical-article-diagnosing-fuel-gauge-malfunction-246.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-electric-windshield-wiper-information-1067.html</guid>
										<title>1958 Corvette:  Service Bulletin:  Electric Windshield Wiper Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-electric-windshield-wiper-information-1067.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-delco-radio-service-parts-1041.html</guid>
										<title>1960 - 1961 Corvette: Service Bulletin: Delco Radio Service Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-delco-radio-service-parts-1041.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</guid>
										<title>1961 Corvette:  Chevrolet Product Engineering Technical Information:  Spark Plug Electrode Interference With Piston</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</guid>
										<title>1960 Corvette:  Service Update:  Tachometer Erratic Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Spark Plug Fouling - Idle Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-ignition-timing-1151.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Ignition Timing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-ignition-timing-1151.html</link>
