<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-spark-plug-changes-178.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-ignition-distributors-and-engine-timing-892.html</guid>
										<title>1959 Corvette:  Service News:  1959 Ignition Distributors and Engine Timing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-ignition-distributors-and-engine-timing-892.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</guid>
										<title>1960 Corvette:  Service Update:  Tachometer Erratic Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</guid>
										<title>1965 Corvette:  Service News:  Vent the Window Regulator Motor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Spark Plug Fouling - Idle Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-zone-letter-directional-signal-failures-1033.html</guid>
										<title>1955 Corvette:  Zone Letter:  Directional Signal Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-zone-letter-directional-signal-failures-1033.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-1955-corvette-service-bulletin-positioning-directional-signal-flasher-plastic-socket-781.html</guid>
										<title>1954 - 1955 Corvette: Service Bulletin: Positioning Directional Signal Flasher Plastic Socket</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-1955-corvette-service-bulletin-positioning-directional-signal-flasher-plastic-socket-781.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-ignition-timing-1151.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Ignition Timing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-ignition-timing-1151.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-chevrolet-partsmart-chevrolet-generator-parts-and-numbers-1086.html</guid>
										<title>1958 Corvette:  Chevrolet PartsMart:  Chevrolet Generator Parts and Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-chevrolet-partsmart-chevrolet-generator-parts-and-numbers-1086.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-delco-radio-service-parts-1041.html</guid>
										<title>1960 - 1961 Corvette: Service Bulletin: Delco Radio Service Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-delco-radio-service-parts-1041.html</link>
