<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</guid>
										<title>1961 Corvette:  Chevrolet Product Engineering Technical Information:  Spark Plug Electrode Interference With Piston</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</guid>
										<title>1955 Corvette:  Service Bulletin: Oil Pump Suction Pipe</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-1957-passenger-car-and-truck-camshaft-identification-769.html</guid>
										<title>1957 Corvette: Service Bulletin: 1957 Passenger Car and Truck Camshaft Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-1957-passenger-car-and-truck-camshaft-identification-769.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1960-corvette-factory-letter-rochester-fuel-injection-127.html</guid>
										<title>1958 - 1960 Corvette: Factory Letter - Rochester Fuel Injection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1960-corvette-factory-letter-rochester-fuel-injection-127.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</guid>
										<title>1961 Corvette: Service Bulletin: Hydraulic Lifter Usage and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</guid>
										<title>1960 - 1961 Corvette: Zone Letter: Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-field-service-bulletin-throttle-return-spring-kit-770.html</guid>
										<title>1957 Corvette: Field Service Bulletin: Throttle Return Spring Kit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-field-service-bulletin-throttle-return-spring-kit-770.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1961-corvette-service-bulletin-fuel-pump-diaphragm-leakage-767.html</guid>
										<title>1958 - 1961 Corvette: Service Bulletin: Fuel Pump Diaphragm Leakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-1961-corvette-service-bulletin-fuel-pump-diaphragm-leakage-767.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</guid>
										<title>1953 - 1958 Corvette: Service Bulletin: Fuel Filter Element Maintenance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</guid>
										<title>1954 Corvette: Service Bulletin: New Valve Spring - High Lift Cam Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</link>
