<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1962-corvette-intake-manifold-casting-numbers-and-date-codes-1179.html</guid>
										<title>1956 - 1962 Corvette:  Intake Manifold Casting Numbers and Date Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1962-corvette-intake-manifold-casting-numbers-and-date-codes-1179.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</guid>
										<title>1961 Corvette: Service Bulletin: Hydraulic Lifter Usage and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</guid>
										<title>1955 - 1956 Corvette:  Service Bulletin:  Inlet Manifold Oil Guards</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-bulletin-fuel-economy-drop-rochester-fuel-injection-service-update-165.html</guid>
										<title>1957 - 1958 Corvette: Service Bulletin: Fuel Economy Drop - Rochester Fuel Injection Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-bulletin-fuel-economy-drop-rochester-fuel-injection-service-update-165.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</guid>
										<title>1955 - 1958 Corvette:  Service Bulletin:  Skinner Oil Savers for 1958 and Older Model V-8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-news-corvette-fuel-injection-760.html</guid>
										<title>1962 Corvette: Service News: Corvette Fuel Injection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-news-corvette-fuel-injection-760.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Oil Consumption</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</guid>
										<title>1953 - 1959 Corvette: Connecting Rod Bearing Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</guid>
										<title>1955 Corvette: Service Bulletin: V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
