<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-driveline-clicking-or-snapping-noise-173.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</guid>
										<title>1974 - 1975 Corvette: Service Bulletin: Stripped Speedometer Driven Gear, 1974-1975 Corvette with 4-Spd. Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</guid>
										<title>1981 Corvette:  Service Bulletin:  Whistle or Whine in Reverse or Lo 1 at Idle - THM 350C (MX3)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-whistle-or-whine-in-reverse-or-lo-1-at-idle-thm-350c-mx3-984.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Evaluating Peened Spacer Plate (Service Information)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-evaluating-peened-spacer-plate-service-information-701.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</guid>
										<title>1974 - 1975 Corvette:  Service Bulletin:  Stripped Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</guid>
										<title>1976 - 1990 Corvette: Service Bulletin: New On-Vehicle Service Procedure to Remove Rear Case or Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1990-corvette-service-bulletin-new-on-vehicle-service-procedure-to-remove-rear-case-or-extension-bushing-705.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-loss-of-front-pump-prime-350c-transmissions-703.html</guid>
										<title>1981 Corvette: Service Bulletin: Loss of Front Pump Prime 350C Transmissions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-loss-of-front-pump-prime-350c-transmissions-703.html</link>
