<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Production and Service 1954 Piston Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-1957-passenger-car-and-truck-camshaft-identification-769.html</guid>
										<title>1957 Corvette: Service Bulletin: 1957 Passenger Car and Truck Camshaft Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-1957-passenger-car-and-truck-camshaft-identification-769.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</guid>
										<title>1955 - 1958 Corvette:  Service Bulletin:  Skinner Oil Savers for 1958 and Older Model V-8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</guid>
										<title>1961 Corvette: Service Bulletin: Hydraulic Lifter Usage and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-oil-filler-cap-and-crankcase-breather-1214.html</guid>
										<title>1958 Corvette:  Service Bulletin:  Oil Filler Cap and Crankcase Breather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-oil-filler-cap-and-crankcase-breather-1214.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</guid>
										<title>1953 - 1954 Corvette:  Service Bulletin:  Identification - 1954 Camshafts - Distributor Gears - Camshaft Gears - All Valve Lifters</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</guid>
										<title>1957 - 1961 Corvette: Service Bulletin: Oil Consumption Complaints</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1961-corvette-service-bulletin-oil-consumption-complaints-42.html</link>
