<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1991-corvette-service-information-service-tips-for-supplemental-inflatable-restraint-sir-160.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</guid>
										<title>1979 - 1984 Corvette:  Service Bulletin:  Power Antenna Rod and Cable Service Package</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</guid>
										<title>1984 Corvette:  Recall:  Product Safety Campaign 84C22 Relocation of Cruise Control Servo Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-product-safety-campaign-84c22-relocation-of-cruise-control-servo-assembly-924.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-recall-notice-product-emission-campaign-85c22-high-output-ignition-coil-1130.html</guid>
										<title>1984 - 1985 Corvette:  Recall Notice: Product Emission Campaign 85C22 High Output Ignition Coil</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-recall-notice-product-emission-campaign-85c22-high-output-ignition-coil-1130.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</guid>
										<title>1986 - 1987 Corvette: Service Bulletin: Intermittent No-Start Condition Caused by Vehicle Anti-Theft System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1987-corvette-service-bulletin-intermittent-no-start-condition-caused-by-vehicle-anti-theft-system-577.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</guid>
										<title>1984 - 1996 Corvette:  Wiring and Circuit Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-wiring-and-circuit-identification-1163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</guid>
										<title>1984 - 1989 Corvette: Digital Dash Cluster Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1989-corvette-digital-dash-cluster-repair-585.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</guid>
										<title>1984 - 1996 Corvette: Speedometer Gear Applications and Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-speedometer-gear-applications-and-part-numbers-584.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</guid>
										<title>1990 Corvette: Recall: Instrument Panel Wire Abrasion - Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-instrument-panel-wire-abrasion-repair-566.html</link>
