<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-electrical-schematics-156.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Power Antenna Will Not Retract</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-power-antenna-will-not-retract-576.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1996-corvette-service-bulletin-shortened-range-with-passive-keyless-entry-pke-transmitter-552.html</guid>
										<title>1993 - 1996 Corvette: Service Bulletin: Shortened Range With Passive Keyless Entry (PKE) Transmitter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-1996-corvette-service-bulletin-shortened-range-with-passive-keyless-entry-pke-transmitter-552.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-wiper-motor-starts-in-high-speed-only-572.html</guid>
										<title>1989 - 1990 Corvette: Service Bulletin: Wiper Motor Starts in High Speed Only</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-service-bulletin-wiper-motor-starts-in-high-speed-only-572.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</guid>
										<title>1990 Corvette: Service Manual Update: SEC. 6D4 Spark Plug Coding Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-manual-update-sec-6d4-spark-plug-coding-chart-530.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
