										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-gm-techlink-bluetooth-issues-114.html</guid>
										<title>2009 Corvette: GM TechLink: Bluetooth Issues</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-corvette-gm-techlink-bluetooth-issues-114.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</guid>
										<title>2009 - 2011 Corvette: GM TechLink:  Electronic Brake Control Module Communication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2011-corvette-gm-techlink-electronic-brake-control-module-communication-67.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</guid>
										<title>2006 Corvette: Electrical Schematic:  Horn System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-horn-system-232.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</guid>
										<title>2005 (Canadian Corvettes Only): Recall 04096: Incorrect Air Bag Off Indicator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</guid>
										<title>2005 - 2007 Corvette: Service Bulletin:  Rear Axle Clunk and/or Chatter Type Noise on Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-rear-axle-clunk-and-or-chatter-type-noise-on-turns-171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-instrument-panel-i-p-body-and-general-wiring-harness-repair-199.html</guid>
										<title>2007 Corvette: Service Bulletin: Instrument Panel (I/P), Body and General Wiring Harness Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2007-corvette-service-bulletin-instrument-panel-i-p-body-and-general-wiring-harness-repair-199.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-1332.html</guid>
										<title>2005 - 2013 Corvette: Service Bulletin: #PIC5049A: Fuel Tank Hard to Fill Or Displays 1/2 Tank After Filling - (Oct 22, 2012)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2013-corvette-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-1332.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</guid>
										<title>2005 Corvette: GM TechLink: Low or Completely Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-low-or-completely-discharged-battery-338.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</guid>
										<title>2006 Corvette: Electrical Schematic: Door Locks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-door-locks-213.html</link>
