<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-recall-n212338110-safety-recall-airbag-light-may-not-indicate-malfunction-jun-3-2021-1517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</guid>
										<title>2020 Corvette: Product Safety Recall: N202311160 Drivers May Overlook Open Hood Alerts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</guid>
										<title>2021 Corvette: Service Bulletin: #N212330830-01: Service Update Bulletin - Navigation System Displays Incorrect GPS Location - (Jun 21, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-update-n212332820-service-update-unable-to-access-apps-jun-9-2021-1519.html</guid>
										<title>2021 Corvette: Service Update: #N212332820: Service Update - Unable to Access Apps - (Jun 9, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-update-n212332820-service-update-unable-to-access-apps-jun-9-2021-1519.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #20-NA-123: Malfunction Indicator Lamp (MIL) Illuminated, DTCs U1961, U1983 Set - (Mar 8, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-131-memory-seat-module-does-not-adjust-jun-2-2021-1516.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #21-NA-131: Memory Seat Module Does Not Adjust - (Jun 2, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-131-memory-seat-module-does-not-adjust-jun-2-2021-1516.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-091-information-on-normal-rearview-camera-display-operation-flashing-diamond-spot-or-ufo-like-image-on-rear-view-camera-display-apr-13-2021-1507.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #21-NA-091: Information on Normal Rearview Camera Display Operation - Flashing Diamond - Spot - or UFO like image on Rear View Camera Display - (Apr 13, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-091-information-on-normal-rearview-camera-display-operation-flashing-diamond-spot-or-ufo-like-image-on-rear-view-camera-display-apr-13-2021-1507.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Tips for Over-The-Air Software Programming</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733e-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-oct-5-2020-1452.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5733E: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History - (Oct 5, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733e-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-oct-5-2020-1452.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-157-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-sep-17-2020-1444.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-157: Transport Mode On Message Displayed in Driver Information Center (DIC) and/or Battery Light is Flashing - (Sep 17, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-157-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-sep-17-2020-1444.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-dtcs-set-in-the-tcm-1466.html</guid>
										<title>2020 Corvette: GM TechLink: DTCs Set in the TCM</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-dtcs-set-in-the-tcm-1466.html</link>
