<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-131-memory-seat-module-does-not-adjust-jun-2-2021-1516.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</guid>
										<title>2020 Corvette: Service Bulletin: #N202308320: Customer Satisfaction Program - Radio Display Inoperative Except For Backup Camera - (Oct 1, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Tips for Over-The-Air Software Programming</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pit5796a-drivers-memory-seat-does-not-adjust-move-to-its-full-travel-feb-5-2021-1489.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIT5796A: Drivers Memory Seat Does Not Adjust / Move To Its Full Travel - (Feb 5, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pit5796a-drivers-memory-seat-does-not-adjust-move-to-its-full-travel-feb-5-2021-1489.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #20-NA-123: Malfunction Indicator Lamp (MIL) Illuminated, DTCs U1961, U1983 Set - (Mar 8, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733d-possible-crank-no-start-or-extended-crank-1440.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5733D: Possible Crank No Start or Extended Crank</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733d-possible-crank-no-start-or-extended-crank-1440.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6407c-amplifier-part-restriction-sep-21-2020-1443.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIC6407C: Amplifier Part Restriction - (Sep 21, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6407c-amplifier-part-restriction-sep-21-2020-1443.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5757A: Service Engine Soon Light/Message with DTCs P1967 or P1968 in the TCM - (Nov 2, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pit5817a-ses-mil-dead-battery-dtc-p0700-p2535-u300d-mar-8-2021-1496.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIT5817A: SES MIL / Dead Battery / DTC P0700 P2535 U300D - (Mar 8, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pit5817a-ses-mil-dead-battery-dtc-p0700-p2535-u300d-mar-8-2021-1496.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733e-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-oct-5-2020-1452.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5733E: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History - (Oct 5, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733e-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-oct-5-2020-1452.html</link>
