<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-corvette-brake-service-tips-1513.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6429-addressing-customer-concerns-on-brake-noises-jan-20-2021-1484.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIC6429: Addressing Customer Concerns on Brake Noises - (Jan 20, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6429-addressing-customer-concerns-on-brake-noises-jan-20-2021-1484.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-service-bulletin-17-na-239-information-on-normal-characteristic-vehicle-unable-to-move-after-being-parked-for-an-extended-period-of-time-1450.html</guid>
										<title>2014 - 2020 Corvette:  Service Bulletin: #17-NA-239: Information on Normal Characteristic - Vehicle Unable to Move After Being Parked for an Extended Period of Time</title>
