										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</guid>
										<title>2019 Corvette ZR1: Service Bulletin: #PIC6338B: Service Parts Restriction - ZR1 Carbon Fiber Body Parts and Ground Effects - (Apr 15, 2019)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-296-tire-performance-and-characteristics-sep-12-2016-1304.html</guid>
										<title>2017 Corvette: Service Bulletin:  #16-NA-296: Tire Performance and Characteristics - (Sep 12, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-296-tire-performance-and-characteristics-sep-12-2016-1304.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</guid>
										<title>2017  - 2019 Corvette: Service Bulletin: Information for Corvette Aero Packages</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</guid>
										<title>2019 Corvette ZR1: Recall Notice:  18195 Sensing and Diagnostic Module Fault State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-14-03-10-001c-tire-hop-tire-chatter-during-tight-turns-at-parking-lot-speeds-1325.html</guid>
										<title>2014 - 2017 Corvette:  Service Bulletin:  #14-03-10-001C: Tire Hop / Tire Chatter During Tight Turns at Parking Lot Speeds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-14-03-10-001c-tire-hop-tire-chatter-during-tight-turns-at-parking-lot-speeds-1325.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-service-news-2015-corvette-michelin-pilot-cup-2-tire-tread-pattern-1267.html</guid>
										<title>2015 Corvette:  Service News:  2015 Corvette Michelin Pilot Cup 2 Tire Tread Pattern</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-service-news-2015-corvette-michelin-pilot-cup-2-tire-tread-pattern-1267.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</guid>
										<title>2014 - 2019 Corvette:  Service Bulletin: Oil Change Information for Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-tire-replacement-mounting-information-1393.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: Tire Replacement / Mounting Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-tire-replacement-mounting-information-1393.html</link>
