<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-internal-transmission-faults-not-serviceable-at-the-dealership-1508.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2024-corvette-z06-service-bulletin-n232413030-service-update-lack-of-auto-park-function-mar-25-2024-1523.html</guid>
										<title>2024 Corvette Z06: Service Bulletin: #N232413030: Service Update - Lack of Auto Park Function - (Mar 25, 2024)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2024-corvette-z06-service-bulletin-n232413030-service-update-lack-of-auto-park-function-mar-25-2024-1523.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-corvette-transmission-external-canister-filter-and-maintenance-update-labor-code-added-1527.html</guid>
										<title>2020 - 2024 Corvette: Corvette Transmission External Canister Filter and Maintenance Update, Labor Code Added</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-corvette-transmission-external-canister-filter-and-maintenance-update-labor-code-added-1527.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202316880-service-update-transmission-control-module-tcm-software-error-mismatch-nov-12-2020-1471.html</guid>
										<title>2020 Corvette: Service Bulletin: #N202316880: Service Update - Transmission Control Module (TCM) Software Error/Mismatch - (Nov 12, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202316880-service-update-transmission-control-module-tcm-software-error-mismatch-nov-12-2020-1471.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709c-dual-clutch-transmission-exchange-program-aug-28-2020-1439.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5709C: Dual Clutch Transmission Exchange Program - (Aug 28, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709c-dual-clutch-transmission-exchange-program-aug-28-2020-1439.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709g-dual-clutch-transmission-part-restriction-dec-1-2020-1476.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5709G: Dual Clutch Transmission Part Restriction - (Dec 1, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5709g-dual-clutch-transmission-part-restriction-dec-1-2020-1476.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-2020-corvette-stingray-powertrain-1412.html</guid>
										<title>2020 Corvette: GM TechLink: 2020 Corvette Stingray Powertrain</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-2020-corvette-stingray-powertrain-1412.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-multiple-transmission-dtcs-set-1492.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Multiple Transmission DTCs Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-multiple-transmission-dtcs-set-1492.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-noise-from-the-transmission-area-1528.html</guid>
										<title>2020 - 2024 Corvette: Noise From the Transmission Area</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-noise-from-the-transmission-area-1528.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5709j-dual-clutch-transmission-part-restriction-jan-27-2021-1487.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIP5709J: Dual Clutch Transmission Part Restriction - (Jan 27, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5709j-dual-clutch-transmission-part-restriction-jan-27-2021-1487.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5797-m1l-internal-transmission-faults-related-to-components-not-serviceable-at-the-dealer-level-mar-30-2021-1503.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIP5797: M1L Internal Transmission Faults Related To Components Not Serviceable At The Dealer Level - (Mar 30, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pip5797-m1l-internal-transmission-faults-related-to-components-not-serviceable-at-the-dealer-level-mar-30-2021-1503.html</link>
