										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Active Fuel Management/Dynamic Fuel Management on GM Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-17469-fuel-leaks-at-the-primary-fuel-pump-module-flange-1399.html</guid>
										<title>2014 - 2017 Corvette:  Service Bulletin: 17469 Fuel Leaks at the Primary Fuel Pump Module Flange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-17469-fuel-leaks-at-the-primary-fuel-pump-module-flange-1399.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-15-06-01-002k-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-illuminated-dtc-p0300-set-dec-17-2020-1479.html</guid>
										<title>2014 - 2019 Corvette: Service Bulletin: #15-06-01-002K: Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0300 Set - (Dec 17, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-15-06-01-002k-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-illuminated-dtc-p0300-set-dec-17-2020-1479.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5234C: Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498b-ses-lamp-p050d-p0300-setting-on-a-cold-start-and-or-a-run-rough-warm-with-no-codes-1378.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: #PIP5498B: SES Lamp P050D P0300 Setting On A Cold Start And/Or a Run Rough Warm with No codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-pip5498b-ses-lamp-p050d-p0300-setting-on-a-cold-start-and-or-a-run-rough-warm-with-no-codes-1378.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-surge-misfire-feeling-sensation-during-highway-steady-state-driving-jun-6-2016-1272.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Surge Misfire Feeling Sensation During Highway Steady State Driving - (Jun 6, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-surge-misfire-feeling-sensation-during-highway-steady-state-driving-jun-6-2016-1272.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2012-2017-corvette-service-bulletin-17-na-157-information-on-spin-on-oil-filter-replacement-for-gas-engines-designed-with-new-oil-pump-control-systems-1363.html</guid>
										<title>2012 - 2017 Corvette: Service Bulletin: #17-NA-157: Information on Spin-On Oil Filter Replacement for Gas Engines Designed with New Oil Pump Control Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2012-2017-corvette-service-bulletin-17-na-157-information-on-spin-on-oil-filter-replacement-for-gas-engines-designed-with-new-oil-pump-control-systems-1363.html</link>
