<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pit5817a-ses-mil-dead-battery-dtc-p0700-p2535-u300d-mar-8-2021-1496.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</guid>
										<title>2020 Corvette: Safety Recall:  #N202311160-01: Safety Recall - Drivers May Overlook Open Hood Alerts - (Sep 24, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-recall-n212338110-safety-recall-airbag-light-may-not-indicate-malfunction-jun-3-2021-1517.html</guid>
										<title>2021 Corvette: Recall: #N212338110: Safety Recall - Airbag Light May Not Indicate Malfunction - (Jun 3, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-recall-n212338110-safety-recall-airbag-light-may-not-indicate-malfunction-jun-3-2021-1517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</guid>
										<title>2021 Corvette: Service Bulletin: #20-NA-237: Radio Software Version V152 Update - (Dec 23, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-131-memory-seat-module-does-not-adjust-jun-2-2021-1516.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #21-NA-131: Memory Seat Module Does Not Adjust - (Jun 2, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-131-memory-seat-module-does-not-adjust-jun-2-2021-1516.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733d-possible-crank-no-start-or-extended-crank-1440.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5733D: Possible Crank No Start or Extended Crank</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733d-possible-crank-no-start-or-extended-crank-1440.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</guid>
										<title>2020 Corvette: Product Safety Recall: N202311160 Drivers May Overlook Open Hood Alerts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-091-information-on-normal-rearview-camera-display-operation-flashing-diamond-spot-or-ufo-like-image-on-rear-view-camera-display-apr-13-2021-1507.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #21-NA-091: Information on Normal Rearview Camera Display Operation - Flashing Diamond - Spot - or UFO like image on Rear View Camera Display - (Apr 13, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-091-information-on-normal-rearview-camera-display-operation-flashing-diamond-spot-or-ufo-like-image-on-rear-view-camera-display-apr-13-2021-1507.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-157-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-sep-17-2020-1444.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-157: Transport Mode On Message Displayed in Driver Information Center (DIC) and/or Battery Light is Flashing - (Sep 17, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-157-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-sep-17-2020-1444.html</link>
