<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-099-speaker-noise-or-loss-of-bass-or-low-no-output-of-audio-from-individual-speaker-channels-apr-23-2021-1509.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #21-NA-099: Speaker Noise, or Loss of Bass, or Low / No Output of Audio from Individual Speaker Channels - (Apr 23, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-099-speaker-noise-or-loss-of-bass-or-low-no-output-of-audio-from-individual-speaker-channels-apr-23-2021-1509.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-dtcs-set-in-the-tcm-1466.html</guid>
										<title>2020 Corvette: GM TechLink: DTCs Set in the TCM</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-dtcs-set-in-the-tcm-1466.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</guid>
										<title>2020 Corvette: #PIP5733B: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</guid>
										<title>2020 Corvette: Service Bulletin: #N202308320: Customer Satisfaction Program - Radio Display Inoperative Except For Backup Camera - (Oct 1, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</guid>
										<title>2021 Corvette: Service Bulletin: #N212330830-01: Service Update Bulletin - Navigation System Displays Incorrect GPS Location - (Jun 21, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Tips for Over-The-Air Software Programming</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</guid>
										<title>2020 Corvette: Product Safety Recall: N202311160 Drivers May Overlook Open Hood Alerts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</guid>
										<title>2021 Corvette: Service Bulletin: #20-NA-237: Radio Software Version V152 Update - (Dec 23, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</guid>
										<title>2020 Corvette: Safety Recall:  #N202311160-01: Safety Recall - Drivers May Overlook Open Hood Alerts - (Sep 24, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</link>
