<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-pip5784-8l45-8l90-automatic-transmissions-with-no-movement-after-valve-body-replacement-mar-1-2021-1493.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</guid>
										<title>C7 Corvette:  Service Information:  Transmission Control Lever Knob Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</guid>
										<title>2015 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Harsh Shifts After Mileage Accumulation Without Previous Transmission Repairs and/or Calibration Updates</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-service-bulletin-diagnostic-tip-for-harsh-shifts-after-mileage-accumulation-without-previous-transmission-repairs-and-or-calibration-updates-1286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</guid>
										<title>2015 Corvette:  GM TechLink:  Reprogramming Procedures for the 8L90 8-Speed Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-16-na-361-information-on-transmission-harsh-1-2-shift-upon-first-start-up-shift-of-the-day-under-light-throttle-1354.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #18-NA-285: Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or During a Remote Vehicle Start Event - (Jan 22, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html</guid>
										<title>2016 Corvette:  Recall:  16038 Transmission Oil Cooler Line in Contact with Body Stud</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1324.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin:  Shake and/or Shudder During Light Throttle Acceleration Between 25 and 80 MPH (40 and 128 KM/H) at a Steady State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1324.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-and-grand-sport-service-bulletin-pip5500-whine-growl-noise-cold-below-40*f-4*c-1369.html</guid>
										<title>2017 Corvette Z06 and Grand Sport: Service Bulletin: #PIP5500: Whine growl noise cold (below 40*F/4*C)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-and-grand-sport-service-bulletin-pip5500-whine-growl-noise-cold-below-40*f-4*c-1369.html</link>
