<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-delayed-transmission-engagement-1448.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Delayed Transmission Engagement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-delayed-transmission-engagement-1448.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-175-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1382.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #16-NA-175: Shake and/or Shudder During Light Throttle Acceleration Between 25 and 80 MPH (40 and 128 KM/H) at a Steady State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-175-shake-and-or-shudder-during-light-throttle-acceleration-between-25-and-80-mph-40-and-128-km-h-at-a-steady-state-1382.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-404-harsh-shift-delayed-shift-unwanted-downshift-transmission-stuck-in-one-gear-erratic-shifting-hesitation-or-have-a-malfunction-indicator-lamp-mil-illuminated-1353.html</guid>
										<title>2017 Corvette:  Service Bulletin:  #16-NA-404: Harsh Shift, Delayed Shift, unwanted Downshift, Transmission Stuck in One Gear, Erratic Shifting, Hesitation or Have a Malfunction Indicator Lamp (MIL) Illuminated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-404-harsh-shift-delayed-shift-unwanted-downshift-transmission-stuck-in-one-gear-erratic-shifting-hesitation-or-have-a-malfunction-indicator-lamp-mil-illuminated-1353.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-and-grand-sport-service-bulletin-pip5500-whine-growl-noise-cold-below-40*f-4*c-1369.html</guid>
										<title>2017 Corvette Z06 and Grand Sport: Service Bulletin: #PIP5500: Whine growl noise cold (below 40*F/4*C)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-and-grand-sport-service-bulletin-pip5500-whine-growl-noise-cold-below-40*f-4*c-1369.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</guid>
										<title>2015 Corvette:  GM TechLink:  All New 8L90 8-Speed Automatic Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-all-new-8l90-8-speed-automatic-transmission-1197.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #PIP5437B: 8L45 8L90 Diagnostic Tips for Harsh Shifts and Delayed or Harsh Garage Shift Engagements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-364-delayed-engagement-after-sitting-with-engine-off-clutch-slow-to-fill-1373.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #16-NA-364: Delayed Engagement After Sitting With Engine Off - Clutch Slow to Fill</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-pip5784-8l45-8l90-automatic-transmissions-with-no-movement-after-valve-body-replacement-mar-1-2021-1493.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #PIP5784: 8L45 8L90 Automatic Transmissions With No Movement After Valve Body Replacement - (Mar 1, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-pip5784-8l45-8l90-automatic-transmissions-with-no-movement-after-valve-body-replacement-mar-1-2021-1493.html</link>
