										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-installing-zr1-body-kit-108.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Installing ZR1 Body Kit</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</guid>
										<title>2005 - 2007 Corvette:  Service Bulletin:  Intermittent Spongy Clutch Pedal Sticking To The Floor During Hard Acceleration And High RPM Shifts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-intermittent-spongy-clutch-pedal-sticking-to-the-floor-during-hard-acceleration-and-high-rpm-shifts-186.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</guid>
										<title>2019 Corvette ZR1: Rear Spoiler Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-coolant-entering-engine-cylinders-1404.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Coolant Entering Engine Cylinders</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-coolant-entering-engine-cylinders-1404.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-update-bulletin-18267-flames-from-exhaust-due-to-misfire-flames-self-extinguish-1402.html</guid>
										<title>2019 Corvette ZR1 - Service Update Bulletin - 18267 Flames From Exhaust Due To Misfire - Flames Self Extinguish</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-update-bulletin-18267-flames-from-exhaust-due-to-misfire-flames-self-extinguish-1402.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</guid>
										<title>1997 - 2011 Corvette:  GM TechLink:  Aftermarket Braided Stainless Steel Brake Lines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2011-corvette-gm-techlink-aftermarket-braided-stainless-steel-brake-lines-68.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2021-corvette-service-bulletin-13-03-10-001h-information-on-summer-tire-performance-and-tire-cold-weather-cracking-may-6-2021-1512.html</guid>
										<title>2014 - 2021 Corvette: Service Bulletin: #13-03-10-001H: Information on Summer Tire Performance and Tire Cold Weather Cracking - (May 6, 2021)</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-ceramic-brake-rotors-113.html</guid>
										<title>2009 - 2013 Corvette ZR1: GM TechLink: Ceramic Brake Rotors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2009-2013-corvette-zr1-gm-techlink-ceramic-brake-rotors-113.html</link>
