<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-15-06-01-002k-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-illuminated-dtc-p0300-set-dec-17-2020-1479.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Setting the Timing on Gen 5 V6 and V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-setting-the-timing-on-gen-5-v6-and-v8-engines-1405.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin: #PIP5179D: Extended Crank Cold With DI (Direct Injected) Engines - (Mar 27, 2018)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</guid>
										<title>2019 Corvette:  LT1 LT4 LT5 Engine Oil Part Number Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</guid>
										<title>2017 Corvette Z06: Service Bulletin: #PIP5492: Scraping or Moan Noise heard During Engine Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5492-scraping-or-moan-noise-heard-during-engine-idle-1356.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-17469-fuel-leaks-at-the-primary-fuel-pump-module-flange-1399.html</guid>
										<title>2014 - 2017 Corvette:  Service Bulletin: 17469 Fuel Leaks at the Primary Fuel Pump Module Flange</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-17469-fuel-leaks-at-the-primary-fuel-pump-module-flange-1399.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</guid>
										<title>2014 - 2016 Corvette:  GM TechLink:  Air Filter Box Seal Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-gm-techlink-air-filter-box-seal-leak-1269.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</guid>
										<title>2016 - 2019 Corvette Z06 ZR1: Service Bulletin: #17-NA-408: Information on Charge Air Cooler (CAC) Draining and Filling - DTC P0300 Set - (Oct 9, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</guid>
										<title>2014 - 2015 Corvette: GM TechLink Article: Extended Cold Crank with Direct Injected Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
