<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pip5767-lt5-supercharger-parts-restriction-nov-20-2020-1473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</guid>
										<title>2016 - 2019 Corvette Z06 ZR1: Service Bulletin: #17-NA-408: Information on Charge Air Cooler (CAC) Draining and Filling - DTC P0300 Set - (Oct 9, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-update-bulletin-18267-flames-from-exhaust-due-to-misfire-flames-self-extinguish-1402.html</guid>
										<title>2019 Corvette ZR1 - Service Update Bulletin - 18267 Flames From Exhaust Due To Misfire - Flames Self Extinguish</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-update-bulletin-18267-flames-from-exhaust-due-to-misfire-flames-self-extinguish-1402.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</guid>
										<title>2019 Corvette ZR1: Service Bulletin: #PIC6338B: Service Parts Restriction - ZR1 Carbon Fiber Body Parts and Ground Effects - (Apr 15, 2019)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2021-corvette-service-bulletin-13-03-10-001h-information-on-summer-tire-performance-and-tire-cold-weather-cracking-may-6-2021-1512.html</guid>
										<title>2014 - 2021 Corvette: Service Bulletin: #13-03-10-001H: Information on Summer Tire Performance and Tire Cold Weather Cracking - (May 6, 2021)</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</guid>
										<title>2019 Corvette ZR1: Rear Spoiler Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</guid>
										<title>2017  - 2019 Corvette: Service Bulletin: Information for Corvette Aero Packages</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</guid>
										<title>2019 Corvette:  LT1 LT4 LT5 Engine Oil Part Number Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</link>
