										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-front-fender-and-fascia-realignment-1424.html</guid>
										<title>2020 Corvette: GM TechLink: Front Fender and Fascia Realignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-front-fender-and-fascia-realignment-1424.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</guid>
										<title>1997 - 1998 Corvette: Service Bulletin: Discoloration or Staining of Plenum (Cowl) Air Inlet Screen</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-discoloration-or-staining-of-plenum-cowl-air-inlet-screen-474.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-creak-or-popping-noise-from-roof-near-windshield-a-pillar-replace-plastic-guides-in-roof-striker-361.html</guid>
										<title>2005 Corvette: Service Bulletin: Creak or Popping Noise from Roof Near Windshield/&quot;A&quot; Pillar (Replace Plastic Guides In Roof Striker)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-creak-or-popping-noise-from-roof-near-windshield-a-pillar-replace-plastic-guides-in-roof-striker-361.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-corvette-door-trim-panel-moldings-671.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Corvette Door Trim Panel Moldings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-corvette-door-trim-panel-moldings-671.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-potential-paint-peeling-on-front-fascias-652.html</guid>
										<title>1991 Corvette: Service Bulletin: Potential Paint Peeling on Front Fascias</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-potential-paint-peeling-on-front-fascias-652.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-front-fascia-and-headlight-adjustment-1532.html</guid>
										<title>2020 - 2024 Corvette:  Front Fascia and Headlight Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-front-fascia-and-headlight-adjustment-1532.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</guid>
										<title>1997 Corvette: Service Bulletin: Hatch Will Not Pop Up When Activated in Cold Weather</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-hatch-will-not-pop-up-when-activated-in-cold-weather-465.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-information-on-the-operation-of-the-rear-compartment-lid-hatch-trunk-exterior-release-switch-362.html</guid>
										<title>2005 Corvette: Service Bulletin: Information on the Operation of the Rear Compartment Lid/Hatch/Trunk Exterior Release Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-information-on-the-operation-of-the-rear-compartment-lid-hatch-trunk-exterior-release-switch-362.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-paint-code-release-update-information-665.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Paint Code Release Update Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-paint-code-release-update-information-665.html</link>
