<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-temperature-gauge-147.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Temperature Gauge Erratic During Normalizing Period</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</guid>
										<title>1954 Corvette: Service Bulletin: New Valve Spring - High Lift Cam Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-fuel-injection-fuel-meter-pump-drive-shaft-seal-replacement-911.html</guid>
										<title>1959 Corvette: Fuel Injection Fuel Meter Pump Drive Shaft Seal Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-fuel-injection-fuel-meter-pump-drive-shaft-seal-replacement-911.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Production and Service 1954 Piston Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-decal-added-to-air-cleaner-to-aid-installation-and-prevent-carburetor-linkage-interference-942.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Decal Added to Air Cleaner to Aid Installation and Prevent Carburetor Linkage Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-decal-added-to-air-cleaner-to-aid-installation-and-prevent-carburetor-linkage-interference-942.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</guid>
										<title>1955 Corvette:  Service Bulletin: Oil Pump Suction Pipe</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-bulletin-fuel-economy-drop-rochester-fuel-injection-service-update-165.html</guid>
										<title>1957 - 1958 Corvette: Service Bulletin: Fuel Economy Drop - Rochester Fuel Injection Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-bulletin-fuel-economy-drop-rochester-fuel-injection-service-update-165.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</guid>
										<title>1959 Corvette:  Service News:  Fuel Injection Pump Leakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-fuel-injection-pump-leakage-917.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</guid>
										<title>1961 Corvette: Service Bulletin: Hydraulic Lifter Usage and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</link>
