<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6407c-amplifier-part-restriction-sep-21-2020-1443.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIC6407C: Amplifier Part Restriction - (Sep 21, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6407c-amplifier-part-restriction-sep-21-2020-1443.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5757A: Service Engine Soon Light/Message with DTCs P1967 or P1968 in the TCM - (Nov 2, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-recall-n212338110-safety-recall-airbag-light-may-not-indicate-malfunction-jun-3-2021-1517.html</guid>
										<title>2021 Corvette: Recall: #N212338110: Safety Recall - Airbag Light May Not Indicate Malfunction - (Jun 3, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-recall-n212338110-safety-recall-airbag-light-may-not-indicate-malfunction-jun-3-2021-1517.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-inoperative-hood-release-buttons-1522.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Inoperative Hood Release Buttons</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-inoperative-hood-release-buttons-1522.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</guid>
										<title>2020 Corvette: #PIP5733B: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</guid>
										<title>2021 Corvette: Service Bulletin: #N212330830-01: Service Update Bulletin - Navigation System Displays Incorrect GPS Location - (Jun 21, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</guid>
										<title>2021 Corvette: Service Bulletin: #20-NA-237: Radio Software Version V152 Update - (Dec 23, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</guid>
										<title>2020 Corvette: Safety Recall:  #N202311160-01: Safety Recall - Drivers May Overlook Open Hood Alerts - (Sep 24, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-157-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-sep-17-2020-1444.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-157: Transport Mode On Message Displayed in Driver Information Center (DIC) and/or Battery Light is Flashing - (Sep 17, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-157-transport-mode-on-message-displayed-in-driver-information-center-dic-and-or-battery-light-is-flashing-sep-17-2020-1444.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6434-service-front-suspension-lift-system-message-setting-a-c103c-and-or-c103e-symptom-64-mar-23-2021-1501.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIC6434: Service Front Suspension Lift System Message Setting A C103C And/Or C103E Symptom 64 - (Mar 23, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6434-service-front-suspension-lift-system-message-setting-a-c103c-and-or-c103e-symptom-64-mar-23-2021-1501.html</link>
