<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752f-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-oct-28-2020-1465.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-rushing-air-sound-in-pcv-tube-1421.html</guid>
										<title>2020 Corvette: GM TechLink: Rushing Air Sound in PCV Tube</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-rushing-air-sound-in-pcv-tube-1421.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752a-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-sep-22-2020-1441.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752A: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - (Sep 22, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752a-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-sep-22-2020-1441.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752h-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jan-20-2021-1485.html</guid>
										<title>2020 Corvette Service Bulletin: #PIP5752H: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jan 20, 2021)</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-may-5-2021-1511.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set - (May 5, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-may-5-2021-1511.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752b-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-possible-valve-stem-oct-13-2020-1460.html</guid>
										<title>2020 Corvette Service Bulletin: #PIP5752B: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - Possible Valve Stem - (Oct 13, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752b-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-possible-valve-stem-oct-13-2020-1460.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752m-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jun-1-2021-1518.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752M: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jun 1, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752m-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jun-1-2021-1518.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-236-engine-overheats-or-coolant-leak-under-rear-of-vehicle-feb-10-2021-1490.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-236: Engine Overheats or Coolant Leak Under Rear of Vehicle - (Feb 10, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-236-engine-overheats-or-coolant-leak-under-rear-of-vehicle-feb-10-2021-1490.html</link>
