<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pit5817a-ses-mil-dead-battery-dtc-p0700-p2535-u300d-mar-8-2021-1496.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #PIT5817A: SES MIL / Dead Battery / DTC P0700 P2535 U300D - (Mar 8, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pit5817a-ses-mil-dead-battery-dtc-p0700-p2535-u300d-mar-8-2021-1496.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-21-na-053-radio-software-version-v155-update-jun-3-2021-1515.html</guid>
										<title>2021 Corvette: Service Bulletin: #21-NA-053: Radio Software Version V155 Update - (Jun 3, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-21-na-053-radio-software-version-v155-update-jun-3-2021-1515.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733d-possible-crank-no-start-or-extended-crank-1440.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5733D: Possible Crank No Start or Extended Crank</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733d-possible-crank-no-start-or-extended-crank-1440.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-131-memory-seat-module-does-not-adjust-jun-2-2021-1516.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #21-NA-131: Memory Seat Module Does Not Adjust - (Jun 2, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-131-memory-seat-module-does-not-adjust-jun-2-2021-1516.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #20-NA-123: Malfunction Indicator Lamp (MIL) Illuminated, DTCs U1961, U1983 Set - (Mar 8, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</guid>
										<title>2020 Corvette: Service Bulletin: #N202308320: Customer Satisfaction Program - Radio Display Inoperative Except For Backup Camera - (Oct 1, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</guid>
										<title>2020 Corvette: Safety Recall:  #N202311160-01: Safety Recall - Drivers May Overlook Open Hood Alerts - (Sep 24, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Tips for Over-The-Air Software Programming</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733e-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-oct-5-2020-1452.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5733E: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History - (Oct 5, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733e-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-oct-5-2020-1452.html</link>
