<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-fuel-line-pulsation-sound-1361.html</guid>
										<title>2014 - 2017 Corvette:  GM TechLink:  Fuel Line Pulsation Sound</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-fuel-line-pulsation-sound-1361.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-gm-techlink-track-engine-temperature-on-track-ready-corvettes-1232.html</guid>
										<title>2015 - 2016 Corvette Z06:  GM TechLink:  Track Engine Temperature on Track-Ready Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-gm-techlink-track-engine-temperature-on-track-ready-corvettes-1232.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-6-2l-engine-bell-housing-rattle-1012.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  6.2L Engine Bell Housing Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-6-2l-engine-bell-housing-rattle-1012.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</guid>
										<title>2014 - 2019 Corvette: GM TechLink:  Warble Sound from Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5234C: Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Active Fuel Management/Dynamic Fuel Management on GM Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-lt5-engine-oil-part-number-1388.html</guid>
										<title>2019 Corvette ZR1 - LT5 Engine Oil part number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-lt5-engine-oil-part-number-1388.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
