<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pip5767-lt5-supercharger-parts-restriction-nov-20-2020-1473.html</guid>
										<title>2019 Corvette ZR1:  Service Bulletin: #PIP5767: LT5 Supercharger parts restriction - (Nov 20, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pip5767-lt5-supercharger-parts-restriction-nov-20-2020-1473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-tire-replacement-mounting-information-1393.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: Tire Replacement / Mounting Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-tire-replacement-mounting-information-1393.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</guid>
										<title>2019 Corvette:  LT1 LT4 LT5 Engine Oil Part Number Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</guid>
										<title>2017  - 2019 Corvette: Service Bulletin: Information for Corvette Aero Packages</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-19-na-042-yellow-tint-to-zr1s-hood-and-engine-cover-exposed-carbon-fiber-parts-1408.html</guid>
										<title>2019 Corvette ZR1: Service Bulletin: #19-NA-042: Yellow Tint to ZR1s Hood and Engine Cover Exposed Carbon Fiber Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-19-na-042-yellow-tint-to-zr1s-hood-and-engine-cover-exposed-carbon-fiber-parts-1408.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-update-bulletin-18267-flames-from-exhaust-due-to-misfire-flames-self-extinguish-1402.html</guid>
										<title>2019 Corvette ZR1 - Service Update Bulletin - 18267 Flames From Exhaust Due To Misfire - Flames Self Extinguish</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-update-bulletin-18267-flames-from-exhaust-due-to-misfire-flames-self-extinguish-1402.html</link>
