										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-infotainment-system-upgrade-for-android-auto-feature-1261.html</guid>
										<title>2016 Corvette: Service Bulletin:  Infotainment System Upgrade for Android Auto Feature</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-infotainment-system-upgrade-for-android-auto-feature-1261.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17-na-327-information-for-dead-battery-1384.html</guid>
										<title>2017 Corvette: Service Bulletin:  #17-NA-327: Information for Dead Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-17-na-327-information-for-dead-battery-1384.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</guid>
										<title>2006 - 2017 Corvette:  Service Bulletin:  #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-oil-filter-with-incorrect-label-21.html</guid>
										<title>2014 Corvette:  Techlink Article: Oil Filter with Incorrect Label</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-oil-filter-with-incorrect-label-21.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</guid>
										<title>2019 - 2024 Corvette: Crankshaft Bearing Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Active Fuel Management/Dynamic Fuel Management on GM Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) On, DTC P0300 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</guid>
										<title>2014 - 2019 Corvette: GM TechLink:  Warble Sound from Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-service-bulletin-13417-service-update-for-inventory-and-customer-vehicles-engine-protection-mode-activated-during-aggressive-driving-848.html</guid>
										<title>2014 Corvette: Service Bulletin: 13417 - Service Update for Inventory and Customer Vehicles - Engine Protection Mode Activated During Aggressive Driving</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-service-bulletin-13417-service-update-for-inventory-and-customer-vehicles-engine-protection-mode-activated-during-aggressive-driving-848.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</guid>
										<title>2014 Corvette: GM TechLink Article: Heated Seat May Turn Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</link>
