<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-pic6407c-amplifier-part-restriction-sep-21-2020-1443.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-inoperative-hood-release-buttons-1522.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Inoperative Hood Release Buttons</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-inoperative-hood-release-buttons-1522.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5757A: Service Engine Soon Light/Message with DTCs P1967 or P1968 in the TCM - (Nov 2, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</guid>
										<title>2020 Corvette: Service Bulletin: #N202308320: Customer Satisfaction Program - Radio Display Inoperative Except For Backup Camera - (Oct 1, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202308320-customer-satisfaction-program-radio-display-inoperative-except-for-backup-camera-oct-1-2020-1449.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-update-n212332820-service-update-unable-to-access-apps-jun-9-2021-1519.html</guid>
										<title>2021 Corvette: Service Update: #N212332820: Service Update - Unable to Access Apps - (Jun 9, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-update-n212332820-service-update-unable-to-access-apps-jun-9-2021-1519.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</guid>
										<title>2020 Corvette: #PIP5733B: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-pip5733b-possible-crank-no-start-or-extended-crank-with-dtc-p12a6-set-as-current-or-history-1433.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-042-fuel-gauge-may-intermittently-display-erratic-and-or-empty-readings-malfunction-indicator-lamp-mil-illuminated-dtc-p0462-set-1462.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-099-speaker-noise-or-loss-of-bass-or-low-no-output-of-audio-from-individual-speaker-channels-apr-23-2021-1509.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #21-NA-099: Speaker Noise, or Loss of Bass, or Low / No Output of Audio from Individual Speaker Channels - (Apr 23, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-21-na-099-speaker-noise-or-loss-of-bass-or-low-no-output-of-audio-from-individual-speaker-channels-apr-23-2021-1509.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</guid>
										<title>2020 Corvette: Product Safety Recall: N202311160 Drivers May Overlook Open Hood Alerts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-recall-notice-n202309350-non-compliance-interior-trunk-release-button-inoperative-ten-minutes-after-power-off-1432.html</guid>
										<title>2020 Corvette: Recall Notice: #N202309350: Non-Compliance - Interior Trunk Release Button Inoperative Ten Minutes After Power Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-recall-notice-n202309350-non-compliance-interior-trunk-release-button-inoperative-ten-minutes-after-power-off-1432.html</link>
