										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-236-engine-overheats-or-coolant-leak-under-rear-of-vehicle-feb-10-2021-1490.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-236: Engine Overheats or Coolant Leak Under Rear of Vehicle - (Feb 10, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-236-engine-overheats-or-coolant-leak-under-rear-of-vehicle-feb-10-2021-1490.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</guid>
										<title>2014 - 2015 Corvette: GM TechLink Article: Extended Cold Crank with Direct Injected Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</guid>
										<title>2014 - 2019 Corvette:  Service Bulletin: Oil Change Information for Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5290e-oil-change-information-for-2014-2018-chevrolet-corvette-us-only-1359.html</guid>
										<title>2014 - 2018 Corvette: Service Bulletin: #PIP5290E: Oil Change information For 2014 - 2018 Chevrolet Corvette (US Only)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5290e-oil-change-information-for-2014-2018-chevrolet-corvette-us-only-1359.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) On, DTC P0300 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #15-NA-002: Information on Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</guid>
										<title>2019 Corvette ZR1: Recall Notice:  18195 Sensing and Diagnostic Module Fault State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</link>
