<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752a-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-sep-22-2020-1441.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752b-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-possible-valve-stem-oct-13-2020-1460.html</guid>
										<title>2020 Corvette Service Bulletin: #PIP5752B: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - Possible Valve Stem - (Oct 13, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752b-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-possible-valve-stem-oct-13-2020-1460.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</guid>
										<title>2019 - 2024 Corvette: Crankshaft Bearing Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-2024-corvette-crankshaft-bearing-diagnosis-1529.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-rushing-air-sound-in-pcv-tube-1421.html</guid>
										<title>2020 Corvette: GM TechLink: Rushing Air Sound in PCV Tube</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-rushing-air-sound-in-pcv-tube-1421.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752g-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-nov-20-2020-1474.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752G: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Nov 20, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752g-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-nov-20-2020-1474.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-update-n202319660-service-update-valve-spring-failure-nov-20-2020-1472.html</guid>
										<title>2020 Corvette: Service Update: #N202319660: Service Update - Valve Spring Failure - (Nov 20, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-update-n202319660-service-update-valve-spring-failure-nov-20-2020-1472.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752h-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jan-20-2021-1485.html</guid>
										<title>2020 Corvette Service Bulletin: #PIP5752H: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jan 20, 2021)</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752m-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jun-1-2021-1518.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752M: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Jun 1, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752m-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-jun-1-2021-1518.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752f-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-oct-28-2020-1465.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5752F: Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 - (Oct 28, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752f-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-oct-28-2020-1465.html</link>
