<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5733d-possible-crank-no-start-or-extended-crank-1440.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-217-improved-electronic-limited-slip-differential-elsd-calibration-nov-10-2020-1469.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</guid>
										<title>2020 Corvette: Service Bulletin: #PIP5757A: Service Engine Soon Light/Message with DTCs P1967 or P1968 in the TCM - (Nov 2, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5757a-service-engine-soon-light-message-with-dtcs-p1967-or-p1968-in-the-tcm-nov-2-2020-1461.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</guid>
										<title>2021 Corvette: Service Bulletin: #20-NA-237: Radio Software Version V152 Update - (Dec 23, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-20-na-237-radio-software-version-v152-update-dec-23-2020-1482.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</guid>
										<title>2020 - 2021 Corvette: GM TechLink: Tips for Over-The-Air Software Programming</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-gm-techlink-tips-for-over-the-air-software-programming-1505.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</guid>
										<title>2020 Corvette: Safety Recall:  #N202311160-01: Safety Recall - Drivers May Overlook Open Hood Alerts - (Sep 24, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-n202311160-01-safety-recall-drivers-may-overlook-open-hood-alerts-sep-24-2020-1445.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</guid>
										<title>2021 Corvette: Service Bulletin: #N212330830-01: Service Update Bulletin - Navigation System Displays Incorrect GPS Location - (Jun 21, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-n212330830-01-service-update-bulletin-navigation-system-displays-incorrect-gps-location-jun-21-2021-1520.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-21-na-053-radio-software-version-v155-update-jun-3-2021-1515.html</guid>
										<title>2021 Corvette: Service Bulletin: #21-NA-053: Radio Software Version V155 Update - (Jun 3, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-bulletin-21-na-053-radio-software-version-v155-update-jun-3-2021-1515.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-recall-notice-n202309350-non-compliance-interior-trunk-release-button-inoperative-ten-minutes-after-power-off-1432.html</guid>
										<title>2020 Corvette: Recall Notice: #N202309350: Non-Compliance - Interior Trunk Release Button Inoperative Ten Minutes After Power Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-recall-notice-n202309350-non-compliance-interior-trunk-release-button-inoperative-ten-minutes-after-power-off-1432.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</guid>
										<title>2020 - 2021 Corvette: Service Bulletin: #20-NA-123: Malfunction Indicator Lamp (MIL) Illuminated, DTCs U1961, U1983 Set - (Mar 8, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-bulletin-20-na-123-malfunction-indicator-lamp-mil-illuminated-dtcs-u1961-u1983-set-mar-8-2021-1494.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-update-n212332820-service-update-unable-to-access-apps-jun-9-2021-1519.html</guid>
										<title>2021 Corvette: Service Update: #N212332820: Service Update - Unable to Access Apps - (Jun 9, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2021-corvette-service-update-n212332820-service-update-unable-to-access-apps-jun-9-2021-1519.html</link>
