<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</guid>
										<title>1974 - 1975 Corvette: Service Bulletin: Stripped Speedometer Driven Gear, 1974-1975 Corvette with 4-Spd. Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-1974-1975-corvette-with-4-spd-transmission-684.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</guid>
										<title>1973 + Corvette: Service News: Gear Tooth Contact Pattern Check - All Rear Axle Assemblies</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-gear-tooth-contact-pattern-check-all-rear-axle-assemblies-823.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</guid>
										<title>1982 Corvette:  Service Bulletin:  Output Shaft Speedo Gear Clip Holes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-output-shaft-speedo-gear-clip-holes-1114.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</guid>
										<title>1982 - 1991 Corvette:  Service Bulletin:  3-4 Clutch / 2-4 Band Service Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-3-4-clutch-2-4-band-service-information-1111.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</guid>
										<title>1968 - 1971 Corvette:  Service News:  Front Servo and Front Accumulator Piston Identification - Turbo Hydra-Matic 400 Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1971-corvette-service-news-front-servo-and-front-accumulator-piston-identification-turbo-hydra-matic-400-transmission-1023.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</guid>
										<title>1982 - 1993 Corvette: Service Bulletin: Buzzing Noise at Idle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
