<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5234C: Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</guid>
										<title>2016 - 2019 Corvette Z06 ZR1: Service Bulletin: #17-NA-408: Information on Charge Air Cooler (CAC) Draining and Filling - DTC P0300 Set - (Oct 9, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-harsh-shift-and-rough-idle-conditions-1420.html</guid>
										<title>2014 - 2017 Corvette: GM TechLink: Harsh Shift and Rough Idle Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-harsh-shift-and-rough-idle-conditions-1420.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-rough-idle-or-vibration-989.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Rough Idle or Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-rough-idle-or-vibration-989.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #15-NA-002: Information on Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</guid>
										<title>2006 - 2017 Corvette:  Service Bulletin:  #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</guid>
										<title>2014 Corvette:  GM TechLink:  Oil Leak after the Harmonic Balancer is Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</guid>
										<title>2019 Corvette:  LT1 LT4 LT5 Engine Oil Part Number Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</link>
