<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-l88-esl-bulletin-front-end-roll-during-hard-cornering-143.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</guid>
										<title>1963 - 1971 Corvette: Service News: Lubrication of Rear Wheel Inner Bearings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-rear-wheel-spindle-yoke-snapping-noise-985.html</guid>
										<title>1980 Corvette:  Service Bulletin:  Rear Wheel Spindle Yoke Snapping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-rear-wheel-spindle-yoke-snapping-noise-985.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1982-corvette-frame-specifications-255.html</guid>
										<title>1978 - 1982 Corvette: Frame Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1982-corvette-frame-specifications-255.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</guid>
										<title>1978 - 1979 Corvette: Service News: Access to Right Upper Control Arm Attaching Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-recall-towing-bracket-installation-798.html</guid>
										<title>1980 Corvette: Recall: Towing Bracket Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-recall-towing-bracket-installation-798.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-frame-dimensions-revised-1230.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Frame Dimensions Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-frame-dimensions-revised-1230.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</guid>
										<title>1980 - 1982 Corvette:  Service News:  Differential Side Bearing Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-positraction-chatter-709.html</guid>
										<title>1970+ Corvette: Service Bulletin: Positraction Chatter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-positraction-chatter-709.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-shipping-block-removal-1975-corvettes-shipped-via-rail-873.html</guid>
										<title>1975 Corvette: Service News: Shipping Block Removal - 1975 Corvettes Shipped Via Rail</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-shipping-block-removal-1975-corvettes-shipped-via-rail-873.html</link>
