<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-removal-of-corvette-z51-spoiler-1428.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-buletin-20-na-214-information-on-front-side-door-window-intermittently-auto-reverses-when-going-up-or-down-oct-30-2020-1468.html</guid>
										<title>2020 Corvette: Service Buletin: #20-NA-214: Information on Front Side Door Window Intermittently Auto Reverses When Going Up or Down - (Oct 30, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-buletin-20-na-214-information-on-front-side-door-window-intermittently-auto-reverses-when-going-up-or-down-oct-30-2020-1468.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-corvette-exterior-protective-cover-removal-1437.html</guid>
										<title>2020 Corvette: GM TechLink: Corvette Exterior Protective Cover Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-corvette-exterior-protective-cover-removal-1437.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-quarter-panel-rattle-sound-1427.html</guid>
										<title>2020 Corvette: GM TechLink: Quarter Panel Rattle Sound</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-quarter-panel-rattle-sound-1427.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</guid>
										<title>2020 Corvette: Product Safety Recall: N202311160 Drivers May Overlook Open Hood Alerts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-product-safety-recall-n202311160-drivers-may-overlook-open-hood-alerts-1434.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-172-remote-keyless-entry-rke-system-operational-change-for-front-trunk-function-1438.html</guid>
										<title>2020 Corvette: Service Bulletin: #20-NA-172: Remote Keyless Entry (RKE) System Operational Change for Front Trunk Function</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-172-remote-keyless-entry-rke-system-operational-change-for-front-trunk-function-1438.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-front-fender-and-fascia-realignment-1424.html</guid>
										<title>2020 Corvette: GM TechLink: Front Fender and Fascia Realignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-front-fender-and-fascia-realignment-1424.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202302840-service-update-door-paint-chipping-1414.html</guid>
										<title>2020 Corvette: Service Bulletin: #N202302840: Service Update - Door Paint Chipping</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-n202302840-service-update-door-paint-chipping-1414.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-update-bulletin-n212327740-service-update-hvac-condensate-drain-hose-not-fully-installed-mar-10-2021-1497.html</guid>
										<title>2020 - 2021 Corvette - Service Update Bulletin: #N212327740: Service Update - HVAC Condensate Drain Hose Not Fully Installed - (Mar 10, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-service-update-bulletin-n212327740-service-update-hvac-condensate-drain-hose-not-fully-installed-mar-10-2021-1497.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-corvette-hood-access-update-1436.html</guid>
										<title>2020 Corvette: GM TechLink: Corvette Hood Access Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-gm-techlink-corvette-hood-access-update-1436.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-convertible-top-water-leak-1530.html</guid>
										<title>2020 - 2024 Corvette: Convertible Top Water Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2024-corvette-convertible-top-water-leak-1530.html</link>
