<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-infotainment-system-upgrade-for-android-auto-feature-1261.html</guid>
										<title>2016 Corvette: Service Bulletin:  Infotainment System Upgrade for Android Auto Feature</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-infotainment-system-upgrade-for-android-auto-feature-1261.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pic6193b-cannot-save-xm-favorites-1308.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: PIC6193B: Cannot Save XM Favorites</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pic6193b-cannot-save-xm-favorites-1308.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</guid>
										<title>2014 Corvette: GM TechLink Article: Heated Seat May Turn Off</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-heated-seat-may-turn-off-1.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-blank-touch-screen-after-start-up-and-in-reverse-7.html</guid>
										<title>2014 Corvette: GM TechLink Article: Blank Touch Screen after Start-up and in Reverse</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-blank-touch-screen-after-start-up-and-in-reverse-7.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-29-2016-1287.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  #16-NA-188: Loss of Radio Controls and/or HVAC Controls - (Jun 29, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-29-2016-1287.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5467a-repeat-codes-p2096-and-p2098-1383.html</guid>
										<title>2014 - 2017 Corvette: Service Bulletin: #PIP5467A: Repeat Codes P2096 and P2098</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5467a-repeat-codes-p2096-and-p2098-1383.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-radio-control-assembly-replacement-11.html</guid>
										<title>2014 Corvette: GM TechLink Article: Corvette Radio Control Assembly Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-corvette-radio-control-assembly-replacement-11.html</link>
