<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-harsh-shift-and-rough-idle-conditions-1420.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-oil-filter-with-incorrect-label-21.html</guid>
										<title>2014 Corvette:  Techlink Article: Oil Filter with Incorrect Label</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-techlink-article-oil-filter-with-incorrect-label-21.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-fuel-line-pulsation-sound-1361.html</guid>
										<title>2014 - 2017 Corvette:  GM TechLink:  Fuel Line Pulsation Sound</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-gm-techlink-fuel-line-pulsation-sound-1361.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</guid>
										<title>2015 - 2017 Corvette:  Service Bulletin: #15-NA-002: Information on Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-gm-techlink-supercharger-idler-pulley-sounds-1362.html</guid>
										<title>2017 Corvette Z06: GM TechLink: Supercharger Idler Pulley Sounds</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-gm-techlink-supercharger-idler-pulley-sounds-1362.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</guid>
										<title>2015 - 2018 Corvette Z06: Special Coverage Adjustment - N202302720 On Track Performance Engine Overheating</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1488.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</guid>
										<title>2014 - 2019 Corvette: GM TechLink:  Warble Sound from Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</guid>
										<title>2016 - 2019 Corvette Z06 ZR1: Service Bulletin: #17-NA-408: Information on Charge Air Cooler (CAC) Draining and Filling - DTC P0300 Set - (Oct 9, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-engine-oil-capacities-1030.html</guid>
										<title>2014 - 2015 Corvette:  Engine Oil Capacities</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-engine-oil-capacities-1030.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</guid>
										<title>2014 - 2015 Corvette:  Service Bulletin:  16009 Primary Tank Inlet Check Valve Fuel and Vapor Leaks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-16009-primary-tank-inlet-check-valve-fuel-and-vapor-leaks-1312.html</link>
