<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-coolant-entering-engine-cylinders-1404.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</guid>
										<title>2019 Corvette ZR1: Rear Spoiler Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Active Fuel Management/Dynamic Fuel Management on GM Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-active-fuel-management-dynamic-fuel-management-on-gm-models-1418.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</guid>
										<title>2014 - 2015 Corvette:  Service News:  Engine Repair with Crankshaft Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-engine-repair-with-crankshaft-replacement-961.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-rough-idle-or-vibration-989.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Rough Idle or Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-rough-idle-or-vibration-989.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-gm-techlink-hard-shifting-into-1st-gear-or-reverse-1379.html</guid>
										<title>2015 - 2018 Corvette Z06:  GM TechLink:  Hard Shifting into 1st Gear or Reverse</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-gm-techlink-hard-shifting-into-1st-gear-or-reverse-1379.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</guid>
										<title>2017  - 2019 Corvette: Service Bulletin: Information for Corvette Aero Packages</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5485-supercharger-whine-noise-mar-14-2017-1334.html</guid>
										<title>2017 Corvette Z06:  Service Bulletin:  #PIP5485: Supercharger Whine Noise - (Mar 14, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-z06-service-bulletin-pip5485-supercharger-whine-noise-mar-14-2017-1334.html</link>
