<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-update-bulletin-18267-flames-from-exhaust-due-to-misfire-flames-self-extinguish-1402.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</guid>
										<title>2019 Corvette ZR1: Recall Notice:  18195 Sensing and Diagnostic Module Fault State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pip5767-lt5-supercharger-parts-restriction-nov-20-2020-1473.html</guid>
										<title>2019 Corvette ZR1:  Service Bulletin: #PIP5767: LT5 Supercharger parts restriction - (Nov 20, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pip5767-lt5-supercharger-parts-restriction-nov-20-2020-1473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-and-z06-pdi-corvette-zr1-and-z06-wide-brake-cooling-deflector-installation-1390.html</guid>
										<title>2019 Corvette ZR1 and Z06:  PDI - Corvette ZR1 and Z06 Wide Brake Cooling Deflector Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-and-z06-pdi-corvette-zr1-and-z06-wide-brake-cooling-deflector-installation-1390.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</guid>
										<title>2019 Corvette:  LT1 LT4 LT5 Engine Oil Part Number Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</guid>
										<title>2019 Corvette ZR1: Rear Spoiler Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-rear-spoiler-adjustment-1403.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-coolant-entering-engine-cylinders-1404.html</guid>
										<title>2016 - 2019 Corvette: GM TechLink: Coolant Entering Engine Cylinders</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-gm-techlink-coolant-entering-engine-cylinders-1404.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</guid>
										<title>2019 Corvette ZR1: Service Bulletin: #PIC6338B: Service Parts Restriction - ZR1 Carbon Fiber Body Parts and Ground Effects - (Apr 15, 2019)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-tire-replacement-mounting-information-1393.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: Tire Replacement / Mounting Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-tire-replacement-mounting-information-1393.html</link>
