<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</guid>
										<title>2019 Corvette:  LT1 LT4 LT5 Engine Oil Part Number Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</guid>
										<title>2019 Corvette ZR1: Service Bulletin: #PIC6338B: Service Parts Restriction - ZR1 Carbon Fiber Body Parts and Ground Effects - (Apr 15, 2019)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pic6338b-service-parts-restriction-zr1-carbon-fiber-body-parts-and-ground-effects-apr-15-2019-1453.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-grand-sport-z06-zr1-stingray-z51-service-bulletin-13-03-10-001g-information-on-summer-tire-performance-and-tire-cold-weather-cracking-oct-9-2020-1456.html</guid>
										<title>2014 - 2020 Corvette Grand Sport Z06 ZR1 Stingray Z51: Service Bulletin: #13-03-10-001G: Information on Summer Tire Performance and Tire Cold Weather Cracking - (Oct 9, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-grand-sport-z06-zr1-stingray-z51-service-bulletin-13-03-10-001g-information-on-summer-tire-performance-and-tire-cold-weather-cracking-oct-9-2020-1456.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-19-na-042-yellow-tint-to-zr1s-hood-and-engine-cover-exposed-carbon-fiber-parts-1408.html</guid>
										<title>2019 Corvette ZR1: Service Bulletin: #19-NA-042: Yellow Tint to ZR1s Hood and Engine Cover Exposed Carbon Fiber Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-19-na-042-yellow-tint-to-zr1s-hood-and-engine-cover-exposed-carbon-fiber-parts-1408.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-lt5-engine-oil-part-number-1388.html</guid>
										<title>2019 Corvette ZR1 - LT5 Engine Oil part number</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-lt5-engine-oil-part-number-1388.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</guid>
										<title>2017  - 2019 Corvette: Service Bulletin: Information for Corvette Aero Packages</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-2019-corvette-service-bulletin-information-for-corvette-aero-packages-1394.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</guid>
										<title>2014 - 2019 Corvette:  Service Bulletin: Oil Change Information for Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</link>
