<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-lt1-lt4-lt5-engine-oil-part-number-update-1389.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Break-In Oil Change for Corvette Included in Chevrolet Complete Care Program</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-break-in-oil-change-for-corvette-included-in-chevrolet-complete-care-program-1122.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  Code P06DD No Or Low Oil Pressure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-code-p06dd-no-or-low-oil-pressure-1280.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</guid>
										<title>2014 - 2015 Corvette: GM TechLink Article: Extended Cold Crank with Direct Injected Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) On, DTC P0300 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-on-dtc-p0300-set-1291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</guid>
										<title>2014 - 2019 Corvette: GM TechLink:  Warble Sound from Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-gm-techlink-warble-sound-from-rear-of-vehicle-1435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</guid>
										<title>2014 - 2019 Corvette:  Service Bulletin: Oil Change Information for Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</guid>
										<title>2006 - 2017 Corvette:  Service Bulletin:  #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2017-corvette-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-1344.html</link>
