<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-lt5-engine-oil-part-number-1388.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pip5767-lt5-supercharger-parts-restriction-nov-20-2020-1473.html</guid>
										<title>2019 Corvette ZR1:  Service Bulletin: #PIP5767: LT5 Supercharger parts restriction - (Nov 20, 2020)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-pip5767-lt5-supercharger-parts-restriction-nov-20-2020-1473.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-and-z06-pdi-corvette-zr1-and-z06-wide-brake-cooling-deflector-installation-1390.html</guid>
										<title>2019 Corvette ZR1 and Z06:  PDI - Corvette ZR1 and Z06 Wide Brake Cooling Deflector Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-and-z06-pdi-corvette-zr1-and-z06-wide-brake-cooling-deflector-installation-1390.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</guid>
										<title>2014 - 2019 Corvette:  Service Bulletin: Oil Change Information for Chevrolet Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-oil-change-information-for-chevrolet-corvette-1397.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</guid>
										<title>2019 Corvette ZR1: Recall Notice:  18195 Sensing and Diagnostic Module Fault State</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-recall-notice-18195-sensing-and-diagnostic-module-fault-state-1396.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-19-na-042-yellow-tint-to-zr1s-hood-and-engine-cover-exposed-carbon-fiber-parts-1408.html</guid>
										<title>2019 Corvette ZR1: Service Bulletin: #19-NA-042: Yellow Tint to ZR1s Hood and Engine Cover Exposed Carbon Fiber Parts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2019-corvette-zr1-service-bulletin-19-na-042-yellow-tint-to-zr1s-hood-and-engine-cover-exposed-carbon-fiber-parts-1408.html</link>
