<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5467a-repeat-codes-p2096-and-p2098-1383.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</guid>
										<title>2005 - 2019 Corvette: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2019-corvette-gm-techlink-power-folding-top-diagnostic-tips-1410.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-13-2016-1278.html</guid>
										<title>2014 - 2016 Corvette: Service Bulletin: #16-NA-188: Loss of Radio Controls and/or HVAC Controls - (Jun 13, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-13-2016-1278.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PIP5159B: Engine Misfire May Be Due To loose Spark Plug Wires</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pip5159b-engine-misfire-may-be-due-to-loose-spark-plug-wires-1309.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-infotainment-display-screen-conditions-1159.html</guid>
										<title>2015 Corvette:  GM TechLink:  Infotainment Display Screen Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-infotainment-display-screen-conditions-1159.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PI1410A: Normal Characteristic - Instrument Panel Red Brake Light Intermittently Comes On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-vehicle-time-out-for-parasitic-draw-testing-1318.html</guid>
										<title>2017 Corvette: Service Bulletin: Vehicle Time Out for Parasitic Draw Testing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-vehicle-time-out-for-parasitic-draw-testing-1318.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</guid>
										<title>2005 - 2016 Corvette: 15521 - Customer Advisory Letter - Side Door Release Operation - Phase 2 Mailing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2016-corvette-15521-customer-advisory-letter-side-door-release-operation-phase-2-mailing-1268.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</guid>
										<title>2014 Corvette: GM TechLink Article: HVAC Temperature Fluctuations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-article-hvac-temperature-fluctuations-4.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-pic6439-diagnostic-tip-for-a-b1517-dtc-battery-negative-cable-jun-25-2021-1521.html</guid>
										<title>2014 - 2019 Corvette: Service Bulletin: #PIC6439: Diagnostic Tip for a B1517 DTC - Battery Negative Cable - (Jun 25, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-pic6439-diagnostic-tip-for-a-b1517-dtc-battery-negative-cable-jun-25-2021-1521.html</link>
